    Hello -
    I just got a second Surface Pro 4 (replacing my first due to constant blue screens and driver issues, which I guess are actually "normal" even after the 11/2 update and the 11/12 TH2 update). Either way, when I put this on to sleep, it drains the battery at a crazy rate. I have it set to hibernate after 2 hours of sleep (that is the default) and when I do the sleepstudy through the cmd prompt, it is just insane. I got a 34% battery drain in the first 2 hour sleep and another 41% drain after the second. The first time, the culprits were the GPU and CPU (no programs are given, just system processes) and the second time it was WiFi (which is odd because I've already said to turn wifi off in sleep).
    Any ideas? I use a pin / don't require sign-in / password, so windows Hello is not even an option to turn off since it is already off.
    Thanks
    11-14-2015 11:34 AM
  2. rockstarzzz's Avatar
    Can you try by stopping all background apps first and then turning one on at a time. May be don't turn on more than one app per day?
    Laura Knotek likes this.
    11-14-2015 03:11 PM
  1. Why can't my phone connect to my PC?
    By Windows Central Question in forum Windows Phones
    Last Post: 11-14-2015, 03:14 PM
  2. how do you remove not for resale when booting lumia 520
    Last Post: 11-14-2015, 12:02 PM
  3. Why aren't I able to sign into my MS account?
    Last Post: 11-14-2015, 11:43 AM
  4. Does anyone make Lumia 820 custom covers (not the protection)?
    Last Post: 11-14-2015, 11:15 AM
  5. Replies: 0
    Last Post: 11-14-2015, 10:05 AM
