My display detaches on the bottom side of Surface Pro 4, is there a fix?
  • Start date
My display detaches on the bottom side of sueface pro 4
i have a big problem with my new surface pro 4. The whole display detatches on the area of the keyboard connector. if i push the display back into the frame, it will only be good gor some minutes. After some minutes the display pops out again of the magnesium frame.
please help me, what should i do?
7a2eer
Banned
Oct 6, 2015
95
Re: My display detaches on the bottom side of sueface pro 4
The smart choice -- See TechFreak1's response.
Want to do it yourself?
  1. Remove the display with an iOpener. Gently work your way along the adhesive to free the display.
  2. Add adhesive to the metal frame below the display. 3M 1055 2mm double sided tape should work just fine.
  3. Place the display back into the frame, applying adequate pressure for several minutes
  4. You can leave a fairly thick book on top of the tablet overnight, ensuring a sufficient bond is made
DrPendragon
