    i have a big problem with my new surface pro 4. The whole display detatches on the area of the keyboard connector. if i push the display back into the frame, it will only be good gor some minutes. After some minutes the display pops out again of the magnesium frame.
    please help me, what should i do?
    11-22-2015 11:30 AM
  2. TechFreak1's Avatar
    Return it for a replacement as it is a faulty unit.
    11-22-2015 11:58 AM
  3. 7a2eer's Avatar
    The smart choice -- See TechFreak1's response.
    Want to do it yourself?
    1. Remove the display with an iOpener. Gently work your way along the adhesive to free the display.
    2. Add adhesive to the metal frame below the display. 3M 1055 2mm double sided tape should work just fine.
    3. Place the display back into the frame, applying adequate pressure for several minutes
    4. You can leave a fairly thick book on top of the tablet overnight, ensuring a sufficient bond is made
    11-22-2015 12:58 PM
  1. Replies: 13
    Last Post: 12-14-2015, 03:22 PM
  2. Windows mobile and future of it's app situation
    By Weird guy in forum Windows 10
    Last Post: 11-23-2015, 09:08 PM
  3. 950 on screen navigation keys
    By eharris560 in forum Windows Phones
    Last Post: 11-22-2015, 11:38 PM
  4. Where is the hotspot option on a Lumia 640 XL?
    By Windows Central Question in forum Windows Phones
    Last Post: 11-22-2015, 02:18 PM
  5. Replies: 1
    Last Post: 11-22-2015, 12:11 PM
