Originally Posted by
Vivida My Laptop (not a Surface product) has this issue as well. I think it has to do with the display inverter for the display. Maybe someone more tech-savy could go into more detail. I think the display inverter creates a high frequeny required for the LCD screen which also can resonate into an audible high pitch sound.
There are two problems: 1. Not everyone can here these sounds so it is not very unlikely that you will be a few of the Surface owners with this problem and 2. not every Surface product will have this problem even if it is the same model. If you can I would go into some store and try them out.
Thank you for the info, Vivida! Do you know whether there is every any type of work-around for this?
I am very curious to see whether, for example, the lower or higher versions of Surface Pro 4 would also have the same issue, so I will have to take a look when I go into the Microsoft Store.
