1. hanbalfrek's Avatar
    Hi all,
    Iím looking to purchase a Surface Pro 4 for work, but have a question for people who may have more experience with it.
    Iíve decided to go with 16GB RAM, 512 GB HD.
    My undecided is on the CPU, and how it affects battery life, which is my priority.
    Iíve been reading a couple of articles that say, with everything else being equal, the i5 has up to an hour better battery life than the i7.
    The links I found are below.
    ntebookcheck.net/Face-Off-Microsoft-Surface-Pro-4-Core-i7-vs-Surface-Pro-4-Core-i5-vs-Surface-Pro-4-Core-m3.156031.0.html
    lovemysurface.net/surface-pro-4-battery/
    My question is, if anyone can answer, is the i5 really that much more power efficient?
    Will I have better battery life on the i5 than the i7?
    Thanks!
    03-10-2016 05:55 PM
  2. anon(5327127)'s Avatar
    Difficult as there's lots to consider.
    -The i7 will hold value for longer
    -The i7 has the iris 540
    -The i7 has a lower base clock speed (2.2GHz compared to 2.4GHz)
    -The i7 should complete taks faster thus returning to idle faster
    Basically, if you want improved battery life, you'd free the constrained power settings using the reg addition and create custom power profiles. 1 for docked at full speed, one for max battery etc.
    Either way if you have the cash I'd always buy the i7. Others might not agree.
    ramontomzer likes this.
    03-11-2016 06:19 AM
  1. Lumia 735 software vs firmware: Clarification needed
    By Kupuna in forum Windows Phones
    Last Post: 03-13-2016, 05:30 AM
  2. How can I retrieve emails more than 6 months old on Surface Pro 3 with Windows 10?
    By Windows Central Question in forum Microsoft Surface Pro
    Last Post: 03-10-2016, 05:38 PM
  3. Surface Pro 3 price drops on Amazon India
    Last Post: 03-10-2016, 05:00 PM
  4. Decent price for used Surface Pro 2?
    By Nagesh Boppana in forum Microsoft Surface Pro
    Last Post: 03-10-2016, 03:30 PM
  5. More rumors about Alcatel Idol Pro 4's hardware specs pop up
    Last Post: 03-10-2016, 10:30 AM
