Surface Pro 2 will not Power up
Have had the Surface Pro 2 for a couple of years now and have replaced the power cable, keyboard etc as time has gone by which had been fine for a couple of months.
A few weeks ago the keyboard was no longer recognized. I have a number of other Surfaces in the house so checked with other keyboards - no luck. Upgraded to Windows 10 in the hope that perhaps this might fix the issue.
Instead the Surface no longer charges. Have interchanged the power cable with other devices and the cable itself is fine. The light at the power point on the surface is not working either.
As I can no longer charge the surface the fact that the keyboard is not working is no longer an issue
Battery is now totally dead
Any ideas?
Not the light is not on, the charger is perfectly fine - double checked, used other chargers.
The device does not seem to recognise that it has a power source.
Any ideas?
