Primary use: Excel, powerpoint, outlook, programming, and browsing.
Situation: Have been using macbook air - love it but few applications are not supported so decided to switch to windows. Bought surface pro 4 on release - was highly disappointed with battery life - never got more than 4 hours after all the settings suggested on forum. See my post - surface pro 4 terrible battery life do you agree?. I returned it and back to air.
Question: Considering all the recent updates - is surface pro 4 finally bug free and has 7 hours of battery life (considering my use)? In macbook air, I typically get 10 hours of battery life. Would appreciate if you can help with following:
1. Buy SP4 as now it is fully baked and has at least 6 hours of battery life
2. Hold on purchasing SP4
3. Install windows 10 on macbook air
Would appreciate if you can help and share your experience and suggestions.
