Hey all -
I have a new surface pro 4 on the way, and wanted to see if you all had any advice on dual monitor setup.
I've read through the forum and seen quite a few people having difficulty with using dual monitors with their Surface Pro 4 - from what I can tell, it is important to use an active converter if you are converting from the mini displayport on the new style dock (like mini DP to DVI, etc).
So, what I'd like to do is have a set of dual monitors that I can set up to run from both my new surface pro, and my desktop computer (gaming, etc).
I bought 2 of these: http://www.amazon.com/Viewsonic-Monitors-VX2770SMH-LED-VX2370SMH-LED-VX2270SMH-LED/dp/B00Z8WZ7KS
The issue I see is that these monitors have only 1 HDMI and 1 VGA, when I set them on on my desktop computer, I tried the VGA, just not crisp enough for working on daily without eyestrain. I'm now thinking about returning them for something that has 2 hdmi, or DVI or something better. I also considered getting a couple of switches like this, but I'm concerned they just won't work right, something like this: Amazon.com: Sewell 3x1 HDMI Switch with Remote (1.3b Compliant): Electronics
What do you all think? Looking for something in the 27" - 28" range, decent brand that hopefully will last a few years, at under $300, if not under $250.
Any suggestions appreciated -
Pete
Pete
