    I'm having a surface pro i model with 64GB. I'm currently using a 64GB SDXC card and hoping to expand the SD card. Please let me know if I can go for a 256GB SDXC card without any problem?
    06-08-2016 12:57 PM
  2. Vasrias's Avatar
    Yeah, I think somewhere it says it Supports up to 2TB. 256gb are definitely supported.
  3. xandros9's Avatar
    I don't think there is any microSD card it cannot handle yet. (barring defective cards)
    06-08-2016 01:04 PM
  4. Vasrias's Avatar
    06-08-2016 11:23 PM
  5. EMitchell's Avatar
    The highest density card I've been able to find is 128GB. I believe the SDXC has spec'd densities up to 2TB, but I've never seen a spec from Microsoft on the microSD limit for the Surface Pro3. I'm guessing that without cards to verify, they can't claim functionality, but it would certainly make sense that they would over design the capabilities of the card reader circuit.
    06-11-2016 08:28 PM
  1. The Xbox One won't be getting an over-the-air TV DVR feature after all
    Last Post: 06-09-2016, 04:41 PM
  2. Deus Ex: Mankind Divided is getting an arcade shooter mode
    Last Post: 06-08-2016, 12:42 PM
  3. HP working on new apps for Windows 10, possibly for the Elite X3
    Last Post: 06-08-2016, 12:30 PM
  4. Delve for Windows 10 app listing pops up on the Windows Store
    Last Post: 06-08-2016, 12:11 PM
  5. Hitman's third Elusive Target, The Prince, is ready to be taken out
    Last Post: 06-08-2016, 11:30 AM
