I've noticed this weird "bug" when using the Surface Pro 4 pen.
If you open say, sticky notes and drag your pen to the edge to resize the note, the pointer changers to the <--> to allow you to do this. The problem is when you go back to write, the pointer remains as <--> and it is very... very.. annoying.
I've noticed the same "pointer issue" in one note as well while taking notes.
Is anyone else experiencing this problem?
