Same flicker here.
My SP4 will flicker on the bottom third at certain times (seems to make a ghost image of the middle third and write it to the bottom third). Won't flicker if the mouse is moving or something happening on the screen. If I stop the mouse and count to 5 or so the flicker comes back. Doesn't happen all the time so I am thinking heat related. I am going to try removing my procase cover for a few days to see if that makes a difference.
I've had my Surface Pro 4 since release. I had the early on screen flicker problem that was solved by disabling Hyper-V.
Microsoft even released a fix for it.
However, for some reason my screen recently started flickering again (like three days ago). And it's very annoying. I tried disabling Hyper-V but that didn't work. It's still flickering.
I don't think it's a hardware issue because if I have a full screen application open like Dota 2 for example, the game plays fine without any flickering.
Anyone else experiencing this problem?
Happened to mine. The issue is actually quite common and is due to chances in brightness. The device is faulty and its better if you could return/replace it.
I returned mine after that for a full refund because I didn't want to deal with it again. Wanted to go back to Mac but the portability and size of surface pro 4 are the best so still trying to make decisions.
