Originally Posted by
libra89 Aside from the Microsoft store, I'm not sure. I remember hearing that the repair is challenging for Surface products.
Yup, you're right. I've just spoken with an MS support agent. They offer a refurb programme, but it's still quite expensive.
There's no straight battery replacement solution.
Apparently, the batteries are glued in, and also somehow connected directly to the motherboard, so getting to them is super tricky.
Oh well, take care of your surface, folks. If it needs any internal repairs done, it's going to cost big time
