1. Jonnny4's Avatar
    Surface Pro 2017, i5 8Gb, to Surface Pro 7? What do you think the performance difference will be? I am already noticing heavy memory usage in Outlook and Edge when working in class on class work.
    10-17-2019 10:51 AM
  2. anon(5327127)'s Avatar
    Remember.... Windows uses Superfetch so your mem usage isn't necessarily X or Y.
    As for the SP 2017, I can only compare it to the SP6. I've owned both and, frankly, the SP6 is miles ahead of the 2017 model. If you had a Pro 6, I'd say that you should wait for reviews to see the differences. However, as you have a SP5, the SP7 should offer you a whole heap of performance when compared.
    Maybe read the SP6 review to see what you're typically going to get.
    10-18-2019 05:09 AM
  1. Amazon Prime members can save on Ring's refurbished Video Doorbell Pro
    Last Post: 10-17-2019, 10:42 AM
  2. The Duex Pro lets you add a second screen to your laptop at $80 off today
  3. The Philips Fidelio X2HR over-ear headphones have dropped to a new low
    Last Post: 10-17-2019, 10:11 AM
  4. Microsoft Surface Laptop 3: Everything you need to know
  5. Control your lights with your voice using TP-Link's Kasa switch down to $22
    Last Post: 10-17-2019, 09:11 AM
