1. sraina's Avatar
    Has anyone tried using wired USB C headphones with the Surface Pro X? Do they work? I am not having any luck using them
    11-19-2019 08:14 AM
  2. Cruncher04's Avatar
    USB Audio devices should have a generic driver, which is supposed to work. Are you headphone recognized by the device but you dont have any audio?
    sraina likes this.
    11-20-2019 04:03 AM
  3. toddpart's Avatar
    Mine work...just using a pair that came With my phone.
    11-20-2019 12:42 PM
  4. sraina's Avatar
    they were not recognized but then i used another pair and they work well.
    11-22-2019 09:28 PM
  5. vzw8830's Avatar
    I purchased the Surface USBC/3.5 adapter and works perfectly with my QC-25s
    Which USB headphones are you trying to use?
    01-10-2020 12:56 PM
  6. WesleyAC's Avatar
    I have a double adapter situation because that is what I had laying around. USBC to standard USB, then USB to 3.5 adapter. Hooked up to Corsair gaming headphones. All works fine, including the mic.
    02-27-2020 02:04 PM
  1. Viscosity now supports ARM64, allowing you to use OpenVPN on more devices
    Last Post: 11-18-2019, 01:00 PM
  2. I'm using Black Friday to upgrade my gaming chair, don't judge me
    Last Post: 11-18-2019, 12:11 PM
  3. Save $150 on the Beats Studio3 wireless noise-cancelling headphones
    Last Post: 11-18-2019, 10:30 AM
  4. Block out the noise with a $120 discount on these Sony ANC headphones
    Last Post: 11-18-2019, 10:00 AM
  5. Control your HVAC remotely using a discounted ecobee3 lite smart thermostat
    Last Post: 11-18-2019, 08:00 AM
