1. BobPro2's Avatar
    With my SP4 plugged in to external power and in use, it gets warm and it adversely affects touchscreen sensitivity. The touch screen intermittently fails to respond to finger touch both with the on-screen keyboard and with icons on the task bar. It will respond to the pen. When I unplug the power and let it cool down, touch sensitivity will return to normal. Has anyone else had this issue? My SP4 is a few years old and I suppose it could be a hardware problem either with the battery or the cooling system.
    01-27-2020 09:21 AM
  2. MJ Adventures's Avatar
    Well did you get this sorted? Same issue here. Contacted microsoft as it is well known issue related to the battery (getting swollen). Theyre offering replace for free if that happens as long as your device isnt older than 3 years. Mine is so that is the reason why i would never come back to microsoft products. Spending £2000 on the device that will last you 3 years only, joke.
    06-03-2020 04:12 AM
  1. When can i buy a Surface tesseract?
    By goodytwoshoes in forum Microsoft News & Rumors
    Last Post: 01-29-2020, 08:58 AM
  2. Want to try Surface Duo OS? Here's how on Window 10.
    Last Post: 01-24-2020, 12:50 PM
  3. Why Daniel Rubino doesn't care if the Surface Duo's camera is terrible
    Last Post: 01-24-2020, 12:11 PM
  4. Check out how the Surface Neo keyboard could work in this patent
    Last Post: 01-24-2020, 06:00 AM
  5. Would Surface Duo's dual displays make up for a bad camera? (Poll)
    Last Post: 01-23-2020, 11:30 AM
