6029KingStephen
I have found that since I got this week's firmware update, to version 3050.0000.1338.1001, battery performance does seem to be significantly improved, and my tick-over rate on standby is down to 1.5% - used to be over 3%.
Don't know if this helps with the AT&T version, but in Settings -> Mobile Network I have a setting for maximum connection speed which I can change from 4G to 3G.How can you turn off LTE and switch to 3G (not 2G mind you) on AT&T version of Lumia 1020?? Is this even possible?
