And ny phone certainly did not come with a good battery it was horrid, about after the tenth charge or so in increments and no overcharging or undercharging its gotten outstanding
I usually charge it right after or before it hits twenty percent and charge it till hundred and leave it an extra few minutes just to make sure
i got my 1020 and this is my 4th day and i have issues with battery too but i think it is true for all that Lithium ion batteries are bad at first few days of use and it will get better day by day, but I also read that charging lithium ion batteries to 100% is not good also as it degrades the battery life over time. So it says, it is better to discharge it down to 40%-20% then charge it up until 80% only and not at full 100% to keep the battery at optimum level. here is the link though, you might want to read about it.
How Often Should I Charge My Gadget's Battery to Prolong Its Lifespan?
That's reassuring. The battery life is the only thing stopping me from truly enjoying my 1020. Glad to hear that yours has improved though. Maybe there is hope after all
u have no idea how bad my battery life was when I had it, the first week I was trying to do everything possible to do to make it not die every day, It did get better and better until one day I accidentally let it stay charging on 100% for 6 hours and it was like a reset to the goodness, I let it die that day to around 14% then slowly made sure I charged it at the right times and also I find turning everything off like WiFi and data when charging keeps it from overheating when charging, I had a really bad time with overheating during charging, too many things going on while the battery was rebooting, even though I have barely anything on my phone
i hope mine gets better too, i am going to my 5th day of using my 1020, how is yours?
also I have found that usually during charging the battery heats up the back quickly and slowly gets cooler, this has gotten better for me over time, just consider it, if u feel a bit of warmth just give it a while it should cool a little bit, if it gets hotter than I suggest unplug it and charge it in increments, do not just charge it for 20 minutes and decide it is getting hotter, it usually takes from anywhere of 45 minutes to an hour for you to be able to feel a difference on the back of the device.
if i remember correctly, my 1020 starts to heat up when the charge is around 80% to 100% but not too hot, just slightly warm. then when 100% full, i turn it off then turn it on, the battery will display 98% full instead of the 100%.
I did it about 8-10 times for it to make a noticeable improvement, its worth trying to do it for about a week or soReconrevelations,
What you are saying is to let our Lumia 1020 drop to 20%, then recharge back to 100%? How many cycles of this did you preform till you saw the massive battery improvement?
Did you reboot your phone after each charging cycle (when charged to 100%) as well??
Thanks,
can you tell me the exact way you charge yours? what i do is, turn off phone, then turn on, then charge too 100% then turn off again then turn on.
I charge it down to about 20% fully charge it back up but turn it off before you hit 100% and unplug it, let it cool down then restart and finish the full charge, there you go
i charged it to 100% and i slept for about 7 hours, after i woke up, battery is 97% (3% loss in 7 hrs). now i am just connected via wifi without using it, i just turned it on for viber and whatsapp and email incoming messages, and lost 4% over 3 hrs of wifi in lock screen and not doing anything.
