1. alihansayin's Avatar
    I was trying to take bracketing photo and i found problem in camera program. When i set iso and shutter speed, program doesnt let me to change expose level and 3 photos is different expose levels but absolutely no differense .No underexpose.and overexpose. Its not possible to make perfect hdr photo with auto settings because of every photo is different iso and shutter speed.
    01-14-2014 03:42 PM
  2. Mr Lebowski's Avatar
    If you set ISO and shutter speed -you've just LOCKED it into those settings, why would bracketing work? You've locked it into that exposure setting.
    Bracketing only works with AUTO. I just checked and all photos I set to ISO 400 / 1/800 sec
    The 3 pictures -all Exposure compensation were -5.0 and ISO 400 & 1/800 sec and I enabled bracketing.
    01-14-2014 04:10 PM
  3. alihansayin's Avatar
    Bracketing only works with AUTO. I just checked and all photos I set to ISO 400 / 1/800 sec -all Exposure compensation were -5.0 and I enabled bracketing.
    You enabled bracketing but did you check photos expose details after? I am sure your all photos is same. Golden rule to create hdr photo to under and over expose with same iso shutter speed and 0 -1 -2 expose. you are talking about -5 expose.
    01-14-2014 04:21 PM
  4. Moiz Mian's Avatar
    Lol, ok so bracketing works by taking 3 photos with 3 different shutter speeds. Quick, medium, and slow. If you lock shutter speed, you just defeated the way bracketing/HDR works. But on the other hand, you should lock ISO so the noise in the HDR is equal.
    alihansayin likes this.
    01-14-2014 04:32 PM
  5. alihansayin's Avatar
    Yea thanks for explanation. I missunderstood.
    01-14-2014 04:50 PM
  6. Mr Lebowski's Avatar
    IF bracketing worked when I set to -0.5EV to +0.5EV then there would be 3 different EV for the 3 photos I took when I set ISO and shutter speed.
    But there were not all were -0.5. IF bracketing worked when you set ISO and shutter speed when checking picture info one picture would have been -0.5,
    one would have been 0.0 and one would have been +0.5 but that's not what picture info (details) said ALL were -.05. when I checked AFTER I took 3 pictures using bracketing and setting ISO and shutter speed.
    -even when I set bracketing to -1EV to +1EV bracketing was the same when I set ISO and shutter speed when I checked picture info after I took photos. Bracketing does not work when you set ISO and shutter speed. it doesn't matter if you set -1EV to +1EV or -2EV to +2EV etc . Bracketing does not work when you LOCK ISO and Shutter speed by manually setting it. Different EV Bracketing only shows in picture info ( details) when set to AUTO
    01-14-2014 05:03 PM
  1. Nokia Lumia 920 battery improvements after GDR3+BLACK
    By guyjkh in forum Nokia Lumia 920
    Last Post: 02-11-2014, 03:25 PM
  2. Nokia Lumia 1520 coming to Vodafone Ireland, exact date and pricing unknown
    Last Post: 01-29-2014, 04:07 PM
  3. After "Black" update, do you have the "nokia beamer" app?
    By arielwp in forum Nokia Lumia 920
    Last Post: 01-17-2014, 02:00 AM
  4. Using my laptops internet with my nokia 1020
    By Sam Baker in forum Windows Phone 8
    Last Post: 01-15-2014, 05:53 AM
  5. Replies: 2
    Last Post: 01-14-2014, 11:49 AM
