Hi all,
A few months back I started having issues with my Wi-Fi. I turn the phone on and connect to the Wi-Fi and all works fine. I then go to work and it wont connect automatically and when I try manually it just says can't connect. After doing a standard restart it connects fine. I then go back home and refuses to connect again until I reboot and all works fine again. I tried soft reset and hard reset with no joy so flashed the whole thing with the recovery tool which fixed the problem. Now out of nowhere it has started doing it again. Has anyone else experienced this? I'm struggling to find anything googling around and want to avoid the faff of using the recovery tool if possible.
Cheers
Cheers
