How much difference in battery drain between the dark and light themes
xandros9
Nov 12, 2012
16,107
depends:
AMOLED screen: lots, always use the dark theme
LED screen: makes no real difference
LCD*
The 1020 has an AMOLED screen, meaning the above. Darkness highly recommended.
More bright colors means higher power consumption.
But if the battery holds up with it like that and you like the primary white look, feel free. I had a friend who used a Lumia 900 with the white theme. not ideal, but that didn't seem to stop her.
Stefan Holder
427
White theme will impact your battery..since more pixels are being in a constant "on" state, the draw will be greater.. By how much depends on the screen tech in use on your device. AMOLED yup.. Prepare to take a hit. LCD, bit as much..
Steve Adams
Banned
Nov 29, 2013
1,296
Ok, I am averageing 30 percent worse battery life with the light theme compared to the Dark theme. Back on dark. I can get through the day in dark and have over 60 percent battery left, I was down to 20 percent on light.
kuyhaa
