1. 7055's Avatar
    Assuming the 1020 has the wireless charging case of course.
    New Qi Wireless Dock Cradle Holder Charger for LG G3 Nexus 4 5 Lumia 920 BC406 | eBay
    02-11-2015 04:29 PM
  2. worldspy99's Avatar
    If you have Amazon Prime, this option is slightly cheaper and if it does not work then Amazon's return policies are substantially superior to that of Fleabay!
    http://smile.amazon.com/Mikobox-Stan...ywords=tylt+vu
    02-11-2015 05:51 PM
  3. jjmorgan64's Avatar
    The only issue you may have is that the qi on the 1020 is slightly lower on the phone than on the 920, due to the camera.
    Worst case scenario is that you would have to put a small block under the phone to elevate it slightly.
    Chances are it will work fine as is though.
    02-11-2015 05:58 PM
  4. 7055's Avatar
    If I buy this charger, does the time continue to display on the phone screen while it's charging so I can use it as a clock in the middle of the night or does the time eventually go away?
    02-12-2015 05:47 AM
  5. tweedie's Avatar
    I can't say for certain that this exact charger will work, but I know that other cheapo QI chargers for Galaxy works with 1020.
    HOWEVER, it was a hit and miss. the "coil" has to be spot on over the charger bit, and much more difficult with that hump. I would say I probably had about 5% luck.
    02-12-2015 06:01 AM
  6. Harrie-S's Avatar
    You can set "Always show glance screen when charging and disable night mode.
    So yes the time will show all the night. (at least with my nokia QI chargers)
    02-12-2015 06:39 AM
  7. gomezz's Avatar
    It says it is a three coil charger and that it works in landscape mode as well as portrait mode so I would not think that is an issue.
    02-12-2015 06:43 AM
  8. nickisverygood's Avatar
    my 1020's compass no longer works after charging with unofficial qi charger. It's better to be carefall..
    02-26-2015 10:40 PM
  1. Why am I not able to pull down my notification center?
    By avazee in forum Nokia Lumia 930
    Last Post: 06-22-2015, 09:52 AM
  2. Lumia 1020 Camera Grip, Black
    By camaroz1985 in forum Marketplace Archive
    Last Post: 03-31-2015, 10:24 AM
  3. 1520.3 and Artist Backgrounds and Album Artwork not working
    By camaroz1985 in forum Nokia Lumia 1520
    Last Post: 02-13-2015, 03:03 PM
  4. Fast charging with Denim update?
    By Kurt Dowswell in forum Nokia Lumia Icon
    Last Post: 02-12-2015, 03:12 AM
  5. Hi I have a Nokia Lumina 925, does this Ottercase fit my 'phone?
    Last Post: 02-11-2015, 04:52 PM
