1. AmGaD-SaLaH's Avatar
    Hello folks..
    I guess there is seriously something wrong with may battery
    It doesn't last long anymore
    .. After 280 update it's extremely bad doesn't last for 5 hours moderately usage
    After the latest update
    Before the latest update
    Anyone facing the same problem?
    I've hard reset the phone twice bur still the same
    10-27-2014 03:47 PM
  2. realwarder's Avatar
    Make sure you're totally powering off the phone at some point. I.e. power off with no charger attached. Leave it off for 30 seconds before switching on.
    AmGaD-SaLaH likes this.
    10-27-2014 04:00 PM
  3. gpobernardo's Avatar
    Sounds like a battery calibration data issue, where 100% is being reported for a charge that is not really 100%. I have just posted a question here in windowscentral regarding a battery bug that occurred several times, both in Windows Phone 8 and 8.1, and for different phones. From it, I think it seems that switching/changing your phone's regions resets the battery calibration data*. Let us know if this helps.
    * - Keeping the phone plugged in, from 100% in US region it drops to 65% right after my phone restarts when I change the region to my country. Charging all the way to 100% was faster than normal, just over five minutes. In fact, I was able to catch the charge "jump" from 86% to 100% literally in a blink. Switching back to US region dropped the charge to 65%, but then it "jumped" again from 70% to 100% in a split second. Hopefully this time 100% would really mean 100%.
    10-27-2014 04:06 PM
  4. Raviraj Halarnekar's Avatar
    Even i am facing the same problem with my Lumia 620. Apart from that i am not able to connect my phone to my PC.
    10-28-2014 04:30 AM
  5. AmGaD-SaLaH's Avatar
    Thanks did that .. But the problem remains!!
    10-28-2014 07:11 AM
  6. AmGaD-SaLaH's Avatar
    Yeah I guess it's a calibration problem!!
    But I didn't change my region for a long time ..
    But I changed the region now and your are correct... The battery percentage changes from 99% to 64% then I returned to the main region its back to 94%
    WTF is going on ?!?!
    gpobernardo likes this.
    10-28-2014 07:14 AM
  7. AmGaD-SaLaH's Avatar
    Running 8.1 ?
    10-28-2014 07:15 AM
  8. AmGaD-SaLaH's Avatar
    Guys I've done some stuff .. And charged my battery to full .. And it seems fine now .... But I'm still testing
    10-28-2014 12:51 PM
  9. gpobernardo's Avatar
    Keep us posted on your observations. As for my L1020, I haven't noticed changes in the average discharge rate after the "region" bug, though I noticed that the charge doesn't "stay" at 100% for several moments only to decline rapidly after a while - not that it leaves 100% a few minutes after being unplugged, but the decline is a bit more gradual now. The average discharge rate, however, remains the similar.
    10-28-2014 01:07 PM
  10. AmGaD-SaLaH's Avatar
    I guess it fixed !!
    10-29-2014 11:41 AM
  11. gpobernardo's Avatar
    Great news, and battery saver hasn't even been activated yet! Thanks for sharing these.
    10-29-2014 02:34 PM
  12. Kurt Russell Molina's Avatar
    What did you do to make your battery stable? Im planning to downgrade my phone but then they said its just the same battery performance with 8.0 and 8.1
    Please help me!!!
    10-29-2014 06:42 PM
  13. gpobernardo's Avatar
    AmGaD-SaLaH "did some stuff" (ref. post #8), but while waiting you can try charging your phone to 100%, then change your region* so you will be prompted to restart your phone. You should see that as soon as your phone powers up the charge has significantly dropped. Now charge your phone again to 100%, then return to your initial region*. The charge would have dropped again the second time - so charge it again to 100%. You should observed some improvement in battery life as this seems to calibrate the battery** for some reason.
    * - If you're a Cortana user but live outside the US, just change your region (e.g. to the Philippines or any other region compatible with a language you know), then switch is back to US later as mentioned - you will not lose your Cortana settings and notebook, though you will have to pin it again after returning your region.
    ** - Battery calibration normally only occurs after "fully" discharging your battery.
    10-30-2014 06:05 AM
  14. Raviraj Halarnekar's Avatar
    Running 8.1 ?
    Yes.
    10-30-2014 07:22 AM
  15. AmGaD-SaLaH's Avatar
    Okay here is how i fixed it (Lumia 1320)
    1- Remove your SIM Card
    2- Remove your SD Card
    3- Use the phone normally till The phone's battery 0%
    4- Leave the phone with 0% for about 30 Minutes
    5- In case of lumia 1320 Unplug the Battery From the board , Others just remove the battery
    6- Plugin the battery charger , Or better charge it via your Laptop Or Desktop pc
    7- When the battery reaches 50% remove the charged
    8- Wait 3-5 minutes .. then do a soft-reset
    9- Check your battery saver to see the ETA
    10- Charge your phone to 100% + 10 minutes for the next 3 recharge times
    11- Do another soft-reset ..
    12- Turn on location service !! ( it's odd i know , but when closed the battery drained for me )
    13- Place back both of your SD Card + SIM Card
    14- MAKE SURE .. to move the daily use apps to your phone not to your SD Card
    That's all .. my battery fixed just like that
    11-01-2014 02:25 AM
  16. Raviraj Halarnekar's Avatar
    I'll try it out..
    11-01-2014 03:37 AM
  17. AmGaD-SaLaH's Avatar
    I'll try it out..
    That's about the battery problem..
    About your phone not getting recognized by your PC
    What's the OS in your PC ?
    11-01-2014 05:32 AM
  18. daemron's Avatar
    Battery saver keeps discharging battery, haven't had any problems since I turned it off. 1 day and 2 hours from 100 to 11% with random internet sharing to 1-3 devices, playing games, surfing on the net etc. 4G enabled 24/7. L1320 Cyan + DP latest.
    11-01-2014 06:16 AM
  19. Raviraj Halarnekar's Avatar
    My phone still does not connect to my PC. My PC's running on windows 8 Pro x64.
    I think its because of the hidden usb setting.
    http://forums.windowscentral.com/win...one-my-pc.html
    Read post no 12...
    11-01-2014 12:22 PM
  20. AmGaD-SaLaH's Avatar
    Read post no 12...
    I had that problem before .. Is your OS ending with N version? Or just pro ?
    If it's pro .. Then I guess you should upgrade to win8.1
    Raviraj Halarnekar likes this.
    11-02-2014 03:04 AM
  21. Raviraj Halarnekar's Avatar
    Click image for larger version.
    I tried the above steps,the battery saver was showing 1day 15hrs ETA when i charged my phone to 100% at night.But today when i woke up in the morning my phone was OFF.
    The battery drained completely.But i guess there was little improvement.
    I'll try it again.
    I think Denim will sort both my problems.Waiting for Denim desperately.
    11-03-2014 12:27 AM
  22. AmGaD-SaLaH's Avatar
    I'll try it again.
    Make sure no apps were running in the background
    11-04-2014 11:14 AM
  23. Raviraj Halarnekar's Avatar
    I had disabled most of the apps..still no luck..will disable all apps and will report here ..thnks
    11-04-2014 11:04 PM
  24. AmGaD-SaLaH's Avatar
    Now I can get 2 days usage and still 30% left .. I guess my problem is solved ✌
    11-12-2014 07:05 AM
  1. Replies: 10
    Last Post: 07-01-2018, 09:12 AM
  2. I have a problem... please help.
    By mjes201 in forum Windows 10 Insider Preview
    Last Post: 11-04-2014, 08:49 AM
  3. Battery life on my new to me 1520
    By cba191 in forum Nokia Lumia 1520
    Last Post: 10-27-2014, 09:27 PM
  4. Replies: 2
    Last Post: 10-27-2014, 08:28 AM
  5. BV-L4A Battery
    By Fred Wilson2 in forum Nokia Lumia 830
    Last Post: 10-26-2014, 06:35 PM
