Ya there was some error during the update
I'm facing the same problem... Even I have to format/factory reset my phone.. The problem is there is an app called 360 mobile guard who draining out my power(according to my battery pro).. But I can't access to the app coz its not exist in my phone.. Honestly d denim update will cause your phone to run out the power easily..i have no idea anymore... Any suggestion?Battery draining quickly after the DENIM UPDATE any solutions??
If I backup and then do with the Lumia software recovery tool will I get all the apps back ???
