How can I fix a system memory problem in my Lumia 1320?
5hock
System memory problem in lumia 1320
I am facing memory problem in my Nokia Lumia 1320. I had
downloaded some apps and system usage is showing 4.45 GB has
been used where apps usage is only 563.14 MB. one more
thing....earlier it shows some temporarily files around 40 or
50 MB but now it shows 0 bytes...List of apps installed on my
phone memory are Whatsapp, Music, Messenger, MoliPlayer,
VIdeo, Perfect Workout, Lumia Help+Tips, Perfect Recorder,
Audiotica, Once Drive, Games, Truecaller, Calender, Transfer
my Data, Shareit. Battery Saver, Easy Transfer and Podcast. I
had format it 2 times and now again im facing this......plz
help
Captains
369
Re: System memory problem in lumia 1320
transfer all apps that you can to your sd card. They will run fine from there.
Kar98
43
Not all apps will run fine from the sd card. The ones I tried, you'll lose live tile and lockscreen functions.
BevitalGlucoPremium
