Citizen X
I don't actually own an iPhone - never have done!
Neither have I but I do have a sturdy internet connection and access to Google so typing in "iphone wifi issue" isn't that much work. I don't have a problem with people posting about their problems with their Windows Phone but before saying or implying iphones are somehow better with wifi my advice is actually do ten seconds of research on iphones.
Like I said, I own a Nokia 925. Great phone. Rubbish WiFi!
The wifi on ONE Nokia 925 is rubbish. Given the fact you really don't research these things well I don't think you can summarily declare the wifi on all or most 925s "rubbish." I am sure if you type in ANY smartphone that sold in quantity and "wifi" you will find some hits. What you don't ordinarily find is 4000+ post threads complaining about it and major publications running articles exposing the manufacturer aggressively censoring posts.
Anyway before I come to any conclusions regarding any phone I do a lot of hands on research and work myself. Regarding iphones I fiddled with the settings on several iphones. I fiddled with the security protocols on several wifi routers. I had the owner go through three different hand sets acquired over the course of months. I did a major software update. And then I did a software roll back. I made three separate visits to an Apple store and a couple to at&t. I also spent countless hours on the internet research all of that. Then and only then did I declare that there was an issue with the iphone and wifi. Personally I wouldn't touch an iphone simply because of the nightmare I had helping an iphone user with theirs. I have had multiple Windows Phones and never had an issue with wifi.
Some Lumias may have issues with wifi but there is no evidence it occurs anymore than with any other cell phone.
Here is some advice for 1520 owners.
Wait. Don't get the devices during the first week of launch. I never like to be the first with these things. Let the manufacturer work the kinks out.
Update. Do all software updates first thing. Don't rely on automatic updates for your first update. Force it to check and update.
Hard reset. It's a pain in the **** but after doing all available updates do a hard reset.
Return/exchange. When all the above fails try various software and router voodoo you find on forums like this. When you have exhausted all that either return the phone and wait a few months for a different manufacturing batch or try your luck with an exchange. Don't be like those apple idiots that just hang onto their phone and hope Cuppertino will send out a fimware/software fix.
