1. Willy Soughers's Avatar
    Not sure if this has been addressed but its something that still bugs me. My lumia 1520 has, since original purchase from an ATT store, had an issue with brightness... Not the one you think (the dim brightness bug every one had lol). When i have sunlight readability off, the auto brightness is perfect but when i turn it on, the assertive display (saturated colors) are on all the time. And im not sure if that takes a lot of battery or what but its weird that it never works the way it did on my lumia 920. Now, i understand that its different tech but was curious about what experience you've had. Do you leave it on and if so, does the weird excessive brightness annoy you? And hows your battery life while using it? Are the saturated "sunlight readability" colors on at all times the norm?
    10-03-2014 08:13 PM
  2. melvintwj's Avatar
    With sunlight readability turned on, the high contrast/saturation display is constantly on in Auto brightness mode for me. I guess that's normal.
    10-04-2014 10:17 PM
  3. Chris_Kez's Avatar
    I don't think that is normal
    10-05-2014 08:14 AM
  4. Microsoftjunkie's Avatar
    I leave mine on too, but the issue you're describing came after one of the latest updates.
    If I understood you correctly, when sunlight readability mode kicks in, you'll notice how "whiter" not brighter the colors gets. Sometimes it gets stuck in this mode unless you cover the ambient light sensor.
    I've never had any battery problems with my 1520. Sunlight readability always been on and extremely useful everytime I go outside.
    10-05-2014 08:24 AM
  5. Willy Soughers's Avatar
    My issue is its always on and it makes the colors strange. I can understand in daylight but in a room with normal lighting, that's a bit too sensitive.
    10-06-2014 03:49 PM
  6. Microsoftjunkie's Avatar
    I also found out if you aim the screen at any light source; ceiling lights etc, readability mode will kick in. Like I said tho, its alot more sensitive after one of the latest updates. I haven't had that issue since the last glance and/or display updates.
    Willy Soughers likes this.
    10-06-2014 06:17 PM
  1. How do I disable LTE on ATT 1520 used on Rogers?
    By blue1k in forum Nokia Lumia 1520
    Last Post: 08-27-2015, 11:19 PM
  2. App corner is not working in my Lumia 520?
    By Varun Bhargav in forum Ask a Question
    Last Post: 04-01-2015, 05:59 PM
  3. Replies: 7
    Last Post: 11-26-2014, 12:56 PM
  4. No 4G with T-Mobile?
    By StinkyMojo in forum BLU Win HD
    Last Post: 10-16-2014, 12:37 AM
  5. The progress of the call is not visible in the screen.
    Last Post: 10-04-2014, 12:44 AM
