Felix Loo
It's sound great, if replacement battery will make the Lumia 1520 alive. But can I know how much it cost you to replace the lumia 1520 battery pack? I am living in Malaysia, wondering how much should I pay for it.
And now my phone doesn't vibrate anymore either.)
So if I understand you correctly, Denim was a factor in the battery performance going south. Still, the phone saying the battery is critical when it's not seems like a bug to me, as does the immediate shutdown.
Reading through the comments here, it really seems like ive hit a battery problem only.
follow this teardown video its not hard just take your time, and use a hair dryer on the old battery to heat the glue. Its REALLY stuck in there. I recommend ordering a kit with the battery with all the tools you need in it. Also if you are opening up the unit and your usb port is loose like mine was you may want to replace it at the same time I got a replacement for 9$ on ebay.
Good luck
*edit*
apparently I cannot post links
youtube search
disassembly full Nokia Lumia 1520 by Mr. Disassembler
mine starting doing this a few weeks ago. If I stream music over bluetooth or use GPS it will restart. Then it will boot up with 75% power showing. I start it back up and it dies again then says the battery is dead. The phone is worthless. I am going to have to use the iphone 5s I got for my Mother that she refuses to use and I ******* hate iphones.
I was looking forward to the 950XL but my 900 and 1520 both started ****ting the bed after a year and a half. Is the hardware any better? Will the damned thing last 2 years.
Also dont think I'd like Android ;(
yeah I know I am just going to do the AT&T plan where I can get a new phone every 12 months. Work pays for it so if the new hardware is flaky I can get a new one
