1. Siddharth Ramakrishnan's Avatar
    Hi,
    I recently bought the Nokia DT 900 wireless charger. When I am charging the phone using that , phone is getting heat too much.
    I just wonder do any one here use wireless charger on daily basis and found any performance issue in battery. Because I dont want degrade my phone when i have alternatives.
    05-13-2015 03:42 PM
  2. Paul1266's Avatar
    I use wireless charging all the time and not noticed an issue. My tip is to charge little and often when possible which reduces the amount if heat the battery is exposed to. If you are draining it right down then it will get hot and that may reduce the life of the battery to some degree.
    RumoredNow and xandros9 like this.
    05-13-2015 03:50 PM
  3. zkyevolved's Avatar
    It theory it will degrade it. Any heat is bad for your phone. Now, will it affect it so much that it's noticeable? I don't know... If you normally charge and play games, it creates a lot of heat... I find wireless charging more useful than not. I change devices often though, so I don't really mind if it degrades 1-2% extra over 6 months.
    Sent from my Note 4 using Tapatalk
    05-13-2015 03:51 PM
  4. RumoredNow's Avatar
    Make sure you are getting a good spot on the charger pad... If you are too far off the "sweet spot" it can cause heat and slow charge.
    Get this App: Battery | Windows Phone Apps+Games Store (United States)
    Open it up and place your phone on the DT-900. check the Charge Rate. Move the device around until you find the best spot and take note of it.
    05-13-2015 05:37 PM
  5. Siddharth Ramakrishnan's Avatar
    I have fins the sweet spot where it charges fast. But still its getting heat.
    05-17-2015 03:12 PM
  6. RumoredNow's Avatar
    Not too hot when you touch it, I hope. Any charging heats a phone, the faster the charge the greater the heat. I'm guessing your charge rate on Qi is over 25%... Then heat would be normal. Too hot to touch would be a worry. Compare heat and charge rate with factory mains charger.
    05-17-2015 03:17 PM
  1. Battery not lasting a day
    By Shad0wguy in forum Microsoft Band & Band 2
    Last Post: 05-15-2015, 07:51 AM
  2. Why is battery life draining so fast and not holding a charge?
    Last Post: 05-13-2015, 03:24 PM
  3. Cricket Wireless prices the Lumia 640 at $129, available starting May 15
    Last Post: 05-13-2015, 02:42 PM
  4. My Surface says it is locked and frozen, so how do I get it to open?
    By Windows Central Question in forum Microsoft Surface for Windows RT
    Last Post: 05-13-2015, 04:23 AM
  5. So how do I know when my Surface 3 is fully charged?
    By Internaut in forum Microsoft Surface 3
    Last Post: 05-13-2015, 03:19 AM
