ajayden
The best way to check the battery performance on any phone is to hard reset it, then check the performance without any third party apps installed.
After you get a measure of how the battery performs using stock OS, you can install third party apps and check the battery performance.
This way, you will have a comparison for your own phone.
Battery performance cannot be compared to other phones or other OS as the usage and setup varies for every phone and every OS.
My 920 and 1520 gives me 14 hours of battery consistently on W10.
