1. POLAT ALEMDAR's Avatar
    Hi mates! I am using L1520 a year and half.
    Suddenly I faced a big problem on Windows 10 even on 8.1 also.
    The problems :
    1) When battery charge is 100% I use the phone for a few minutes and it shut down directly screen goes off without " good bye " ... When I try to turn it on it reached to Micosoft logo and shut down until I plugg the charger and it start with 38% - 89% battery for example.
    2) sometimes when it shut down and try sometimes to turn it on without charger it dead with no respond until I plugged the charger with no respond until I left it for 7-9 hours after that it turn on and charge and come back to " problem 1 "
    Is this a battery problem ?
    Should I buy a new battery ?
    When I bought it , can I replace it by my self ? Because there is no places to fix Lumia phones in my country.
    Sorry for my bad English.
    01-26-2016 11:44 PM
  2. RumoredNow's Avatar
    Yes.
    Yes.
    Yes.
    01-27-2016 12:11 AM
  3. Bence Benedek's Avatar
    Hi mate yes u have battery issue, i have the same before battery replacement, after that i have 2days of usage and had left 10%, so go'on, its cost in hungary around 60$. There are youtube videos.good luck
    POLAT ALEMDAR likes this.
    01-27-2016 12:16 AM
  4. POLAT ALEMDAR's Avatar
    Thank you all ... I will try
    01-30-2016 12:05 AM
  5. POLAT ALEMDAR's Avatar
    60$ ?? It is too much :(
    can you give me the bran or details about the original battery
    01-30-2016 12:06 AM
  6. Bence Benedek's Avatar
    Yes, i will upload a pic later if that help. but the $60 include the service too so the replacement and the battery, worth it. Prices are different in hungary soo i think much cheaper elsewhere
    02-05-2016 03:22 PM
  1. Replies: 20
    Last Post: 01-30-2016, 12:58 PM
  2. help with phone settings phone vs message alerts L640 att unlocked
    By brusbrother in forum Microsoft Lumia 640
    Last Post: 01-27-2016, 02:28 PM
  3. Help activation of windows 10
    By saurabh7890 in forum Ask a Question
    Last Post: 01-26-2016, 11:11 PM
  4. How do I fix the start restart problem on a Lumia 635?
    Last Post: 01-26-2016, 05:48 PM
