1. maninder4041's Avatar
    my nokia battety is a serious issue for me...it drains very fast..if i use net(2g) it will come down to 20% from 100% within 2 hours.in idle state phone eats around 40% my battery in a day
    but sometimes battery does well.yesterday i used internet for 1 hour and i lost only 15% battery.when battery problem happens upper side of camera heats a lot...i did eveything to find the problem but failed.. looking for reply which could solve this problem
    02-19-2014 08:33 PM
  2. KrisJoeEll's Avatar
    I think these random battery performances is due to your software conditions (background apps, wifi/nfc,bt on) at that time or a faulty hardware.
    But try these tips, see if following these gets you a consistent performence.
    17 tips to extend battery life on Windows Phone 8 | Windows Phone Central
    Tribanj likes this.
    02-19-2014 09:22 PM
  3. SSgt Bruskowiz's Avatar
    Here a few pointers.
    settings/ rightswipe and check whats running in the background.
    Some apps are a real drain.
    Then check your mailaccounts, how often does it sync and is it realy necessary, better is to check manually
    Same as wheaterapps, how more often how much more its drains
    Dim your screen.
    Doubletapp to wake is nice but not necessary, so turn it of.
    Wifisetting/advance, turn the first three of, the last option, timeout can stay activated.
    And if you dont use Gps, turn it of
    Same as bluetooth
    Only turn these options on when needed.
    02-19-2014 09:35 PM
  4. maninder4041's Avatar
    i'll try.every background service is disabled.today i'm using phone for net browsing and no heating,no battery drain problem till now.battery at 85%...
    02-19-2014 09:41 PM
  5. rishabk97's Avatar
    Mobile Data is always a battery drainer. Keep it off whenever possible. WiFi is the best option. And if still your problem persists, try a hard reset.
    Reset my phone | Windows Phone How-to (United States)
    02-19-2014 11:23 PM
  6. Cola79's Avatar
    In my expirience with multiple handsets and operating system, from all data connections WIFI uses most energy. The minimum energy consumption is 2g, followed by 3g. WIFI is good for big downloads, but it is worst for battery, thats why it automatically gets shut down when handsets get into standby.
    02-20-2014 05:38 AM
  7. SSgt Bruskowiz's Avatar
    But if it persist............well its not always the software, it could be a defective unit or battery........
    So he could go to a service point to rule that out.
    I got 3 days from my 520, two if i have to use it al lot.
    02-20-2014 06:41 AM
  8. maninder4041's Avatar
    ok i'll take it to care center and i'll reply what happens after that....
    02-20-2014 06:57 AM
  9. maninder4041's Avatar
    how to hard reset nokia 520
    02-20-2014 09:12 AM
  10. ahmedashraf_22's Avatar
    what if I use a bl-5j battery with 2850mA instead of bl-5j battery with 1430mA ?
    02-20-2014 07:34 PM
  11. SSgt Bruskowiz's Avatar
    Settings/info
    scroll down
    Remember it whipes everything from the internal storage, so back it up to sd or pc/laptop
    02-20-2014 07:54 PM
  12. SSgt Bruskowiz's Avatar
    Nothing, it takes longer to charge and of course you have a longer batterylife
    If you refer to the cheap chinamodels, i must warn you.............they are quite good in relabeling ;-)
    02-20-2014 07:58 PM
  13. ahmedashraf_22's Avatar
    so there is no way to improve my battery life ???
    02-22-2014 06:55 PM
  14. SSgt Bruskowiz's Avatar
    Yes it will
    It only takes twice as much to charge.
    Example...if your charger lets say delivers 500 mh/h its 1430 : 500 = 2,86 ( about 3 Hours )
    With the new batery it would be 2850 : 500 = 5,7 ( about 6 Hours )
    IF its not a ripoff
    I ment with nothing that nothing bad would happend ;-)
    02-22-2014 07:23 PM
  15. ahmedashraf_22's Avatar
    Yes it will
    It only takes twice as to charge.
    And doublle lifetime.
    IF its not a ripoff
    what r u think it would happened ?? and where I can buy an original 2850mA bl-5j ?
    02-22-2014 07:31 PM
  16. SSgt Bruskowiz's Avatar
    Well if the specs are right, you get twice as much juice, so doubble livetime.
    You can buy the original ones at a servicepoint.
    02-22-2014 07:55 PM
  17. Rizwan Ajaz's Avatar
    i have bought lumia 520 two days back... its battery timing is very poor... 3-5% drops every hour unlike what is said in specification.... whats the problem??? i need replies guys??? Help me out plz
    02-24-2014 09:02 AM
  18. SSgt Bruskowiz's Avatar
    At first a new battery needs some time to perform.
    Mostly after a couple of cycles
    At first you check whats running in the background,
    And look at the bluetooth and gps ....turn it of when not needed.
    Also look at the sync of your acounts.
    And ofcourse the wifi settings, if you go advance you find a couple of settings there.
    Turn them al off exept the last one.
    Also if you dont need double tap to wake, turn it of.
    There are a lot of tips giving here on wpcentral.
    Rizwan Ajaz likes this.
    02-24-2014 10:11 AM
  19. Rizwan Ajaz's Avatar
    okay, i hope it works... thanks alot buddy
    02-25-2014 11:04 AM
  1. Why does the Icon lacks the awesome Nokia Glance?
    By Chris Wayne2 in forum Nokia Lumia Icon
    Last Post: 02-23-2014, 04:16 PM
  2. Replies: 2
    Last Post: 02-20-2014, 03:48 PM
  3. Nokia releases a spectacular Lumia app for Mobile World Congress 2014
    Last Post: 02-19-2014, 07:30 PM
  4. how much does nokia charge for repairs?
    By j666w in forum Nokia Lumia 920
    Last Post: 02-19-2014, 05:31 PM
  5. Replies: 0
    Last Post: 02-19-2014, 05:20 PM
