1. jfloyd256's Avatar
    I have installed the apps i need for the Nokia 520 and they work perfectly at home with my internet connection. When i am away for home they do not load proberly, what do i need to change in the settings for them to work ouside my home and will i be charged by my "pay as you go" provider?
    many thanks
    jf
    03-16-2014 06:17 AM
  2. PxuLL's Avatar
    If they require internet connection for instance Instagram to get pictures you will need to go to settings > mobile network > data connection (ON) and pick your connection speed according to your tariff (2G, 3G, 4G)
    03-16-2014 07:16 AM
  1. View more topics in the WP8 app
    By anon5997296 in forum Windows Central for Windows Phone - App Support
    Last Post: 03-24-2014, 12:36 AM
  2. Formula 1 season kicks off this Sunday, follow with ESPN F1 app for Windows Phone
    Last Post: 03-16-2014, 07:51 AM
  3. Problem with amber update
    By Jagadeesh Maroju in forum Nokia Lumia 620
    Last Post: 03-16-2014, 02:07 AM
  4. Check out my first WP8 App - Quotes to...
    By anon4154006 in forum App Spotlight
    Last Post: 03-15-2014, 11:51 PM
  5. First App: Horror Stories in Two Sentences
    By wasim117 in forum App Spotlight
    Last Post: 03-15-2014, 05:39 PM
