1. thephiri2point1's Avatar
    Is it possible to swap my current battery for a bigger size capacity wise but can fit in my L520. Would swapping have any negative effects on the phone?
    05-07-2014 01:41 AM
  2. GVFJR's Avatar
    Zerolemon has a battery that will fit our 520s.i also have a 521 that I am in the process of unlocking and have considered a larger battery for that also.I just saw these this weekend as I purchased my 520 on Saturday and was looking to buy a regular sized spare or just go for the biggest battery available.The negative point to the zerolemon is carrying a much bulkier device.
    05-07-2014 08:27 AM
  3. Akash Patel's Avatar
    But wouldn't 4700mah battery will create problem in Lumia 520 if we use it??
    05-07-2014 08:31 AM
  4. GVFJR's Avatar
    Why would it create a problem?ive used larger capacity batteries on my old android devices without issue.
    05-07-2014 12:27 PM
  5. xandros9's Avatar
    You should be able swap it out without any issues.
    That's part of the point of a swappable battery. Back in the day you would see large extended batteries that were physically larger (and with a back cover to match)
    My only concern would be el cheapo batteries of dubious quality and legitimacy.
    Higher mAh ratings won't hurt the device, its different voltages and batteries not meant for the device in question.
    thephiri2point1 likes this.
    05-07-2014 02:48 PM
  6. thephiri2point1's Avatar
    Thanks for your responses. Will definitely start looking for a bigger battery. Does anyone know what other Nokia uses the same size battery but bigger capacity? Or I'm I stuck with using some chinese battery
    05-08-2014 04:43 AM
  7. Akash Patel's Avatar
    No you wont find anyother model which uses BL-5J battery with bigger capacity.
    You need to buy some other company battery.
    I found this one on the internet
    Still i will first see review of it then only swap my battery.
    http://www.amazon.com/gp/aw/d/B00IS8...pUvbUpU2526575
    thephiri2point1 and xandros9 like this.
    05-08-2014 04:58 AM
  8. Aniket Mhatre's Avatar
    Is there any battery available for lumia 620 and they deliver it to India?
    05-09-2014 09:06 AM
  9. xandros9's Avatar
    You can certainly pick up a spare battery (1300 mAh is the stock capacity) for the 620 online, but as for extended ones I don't know.
    05-09-2014 10:13 AM
  10. Aniket Mhatre's Avatar
    1300 mAh is just waste. Maximum it can last for 5-6 hours. There was mugen 1400 mAh battery but they said they can't deliver to India
    05-09-2014 11:21 AM
  11. Akash Patel's Avatar
    If you are not able to find an extended battery then purchase a powerbank it will cost you less and will be from original nokia.
    Try nokia DC-16 or nokia DC-19
    http://www.flipkart.com/nokia-dc-16-...b_wp&m1k=vb_wp
    http://www.flipkart.com/nokia-dc-19-...b_wp&m1k=vb_wp
    05-09-2014 01:18 PM
  12. Aniket Mhatre's Avatar
    I have dc-16 right now thats my only life line. Hope extended battery comes soon to India
    05-09-2014 01:28 PM
  13. xandros9's Avatar
    but a spare battery is still something, just the inconvenience of swapping. (2 x 1300 mAh = 2600 mAh)
    05-09-2014 02:49 PM
  1. Ads for rt doesnt work
    By Cobb in forum Site Feedback & Help
    Last Post: 05-07-2014, 08:49 AM
  2. NL 820 eating up battery.
    By Sandeep Parandekar in forum Nokia Lumia 820
    Last Post: 05-07-2014, 01:35 AM
  3. Webcam Controller for Surface RT; app for Windows Phone 8.1
    By dvda247 in forum Microsoft Surface for Windows RT
    Last Post: 05-07-2014, 12:15 AM
