gaknigge
this happened to me too. I don't think it is the GDR2 update from Microsoft, but the Amber update from Nokia. I have a Lumia 521. This worked for me.
Best of luck.
- Hard reset
- Toward the end of the install you are prompted to automatically install system updates. Say no to that. This is in the custom options I believe. Walk through thte post-install steps carefully to find it
- This prevents the Amber part of the Amber update installing.
- I installed then from the store the offered HERE apps from Nokia, but none of the others.
Best of luck.
