Do you have WP 8.1 or Lumia Black, if you are still running Amber, then this bug will always be there. As soon as you update it should be fixed, otherwise you can do a soft reset by holding the power button and volume down button.
Best of luck with your WP Handset!
EDIT:- A restart will work too
