Battery saver setting not working anymore
Mhkw
8
Hello people,
I've set my battery saver setiings on "when battery is low". About a month ago my battery was running low and I noticed the "heart symbol" turning on, so it was working. Now, a couple of weeks later when my battery is running low it is not showing the heart symbol anymore. I do still get "your battery is low" notification. I just got the Amber update but still the same problem. Any ideas?
DBDev
2,380
Yes, several times. I also got the amber update a couple of days ago so the phone was also reset. Thanks
Ok, then the only thing I can come upp with is a hard reset, but keep in mind that it will delete everything on your phone.
bevitalglucopre
