Its l 620, it has 1.8 gb as sys 2.6gb as apps 2.3gb as other, & problem is I can't clear other , do you guys have any idea for that
Can't I make it without hard re set?
try thisCan't I make it without hard re set?
Thank you very much Mr. Aniket,it's very grateful, can I ask you one more, when I checked storage check it shows
Apps 2.5gb
media&files 2.6gb
system 1.8gb
free 254mb
and the point is where is media &files?I didn't find it anywhere in my device which killing my2.6gb of storage, and I prefer 8.1 in user version coz I don't have much idea about developer version so can you plz explain me in simple way to remove that from storage, thank you for your kind support,
& one more thing in game hub i just have six gun which occupied 849mb & ae jewels2 as 229mb no more than that and apps I don't have too much so I just think its not good to uninstall and reinstall is the solution, just my opinion,thanksagain
raghu,
