1. vsmh96's Avatar
    the Lumia 620 would no longer charge nor on.
    I tried charging the battery and it worked on another phone,
    the phone however would not start up...
    the last of it when it worked was that my bro put it to charge and was charging after a few minutes it would no longer power on.
    I have tried the buttons thingy but it doesn't seem to work.
    pls advice.
    07-27-2014 03:55 AM
  2. Aniket Mhatre's Avatar
    Nokia software recovery tool. Use it this might help you or get it checked.
    Sent from Lumia 925 India using tapatalk
    vsmh96 likes this.
    07-27-2014 03:57 AM
  3. vsmh96's Avatar
    It isnt working. Please look at the pictures attached.
    07-27-2014 10:16 AM
  4. S Vaibhav's Avatar
    Download, install and open the recovery tool on your PC 💻. Connect your phone via USB(doesn't matter if it doesn't turn on) and select the "my phone does not startup or respond correctly" option. It will locate a firmware for your phone 📞. Download and install the firmware. Your phone will startup correctly.
    07-27-2014 10:21 AM
  5. vsmh96's Avatar
    i did that. not working. those pictures above well that is all i got.
    07-27-2014 10:25 AM
  6. shivam94's Avatar
    Check your device manager in your control panel of your pc for any missing/malfunctioning drivers after connecting your mobile via usb
    07-27-2014 11:03 AM
  7. vsmh96's Avatar
    then? the phone is basically dead
    07-27-2014 11:35 AM
  8. SRLumia620's Avatar
    I would suggest you go to your Nokia Service center and get it fixed. I had a similar problem and I handed it over to them. Turns out it was a problem with my battery terminal. They soldered and fixed it. Been smooth sailing for over a month since then. So I suggest you hand it over.
    Cheers!
    vsmh96 likes this.
    08-02-2014 09:12 AM
  9. vsmh96's Avatar
    I guess that is the only option that I have. Anyway the Samsung charger got fried too(perhaps it was a knock off charger)
    08-02-2014 09:35 PM
  1. OneDrive not working...
    By Vladimir Kraus in forum Ask a Question
    Last Post: 08-02-2014, 04:20 AM
  2. Replies: 33
    Last Post: 07-29-2014, 05:39 PM
  3. Tell me a single way to do FB on WP 8.1 effectively!!
    By anon5997296 in forum Windows Phone 8.1 Preview for Developers
    Last Post: 07-28-2014, 11:22 PM
  4. Replies: 2
    Last Post: 07-27-2014, 10:41 PM
