1. ricardofnsc's Avatar
    I really like my new lumia 625, works great so far and never gave any trouble, I'm quite happy with the unit.
    But I notice that I think the phone has a problem when charging, it charg in about two / three hours, if I take the chain the mobile phone is 100% is normal, but for example if I leave all night charging for about eight hours in the morning when I take the charger mobile phone, 100 passes for 95 instantly (or near values​​).
    is normal this happen?
    02-10-2014 04:28 PM
  2. stamatis1's Avatar
    Of course it is normal...SIgnal itself consumes battery..If you dont wanna have overnight battery drain use airplane mode thats what i do and my l520 after 9:30 hours is down 0.5 - 1 % :P
    2-3 hours is the normal charging rate for every phone i believe.. that depends on your charger/socket too!
    02-10-2014 11:00 PM
  1. Optical Image Stabilization (OIS) camera problem
    By Ookiie in forum Nokia Lumia 920
    Last Post: 03-27-2016, 09:45 AM
  2. Odd problem with time resetting...
    By vaderag in forum Windows Phone 8
    Last Post: 02-13-2014, 06:01 PM
  3. problem in transfering data to PC
    By S A Shah in forum Nokia Lumia 620
    Last Post: 02-12-2014, 12:52 AM
  4. Charging When You Don't Need To
    By Joshua Jackson in forum Toshiba Encore
    Last Post: 02-11-2014, 10:53 AM
  5. Replies: 7
    Last Post: 02-10-2014, 10:10 AM
