USB Connectivity problem.
Shervrar
22
Hi there.
I was wondering weather you (the community) could help me with something. I was hoping to flash the Qualcomm bootloader to my lumia, however when i hold the Volume up button and connect a USB cable (from my WinXP Laptop) to the lumia (while switched off), the device gives me a short vibration and stays in "Nokia connectivity" mode for about 10 seconds. After that it gives me a long vibration and boots normally. While (before) it booted i saw a white battery icon with a red bar for about half a second, however my battery is at 96%! Is there anything i can do to make it stay in developer/recovery/whatever-it-is-called mode?
I hope this makes sense.
Sent from my Lumia 710 using Board Express
graceevans
