1. Neeraj Parihar's Avatar
    Hi guys my lumia 720 is only 2-4 days old and the battery sux big time i don't know what is wrong with it.
    Firsty it takes abt 4hours to charge the battery completely 100% ..is this time normal...?
    Secondly my battery drains fastly sometimes 7%in 19mins..i uses 2g after that too it drains so fastly...somtimes it shows battery is 60% and the nxt tym it jumps to 45% i hv turned off all the background apps...what should i do...? Especially recharge time is 4ht which s pretty annoying..
    08-29-2013 11:44 AM
  2. montsa007's Avatar
    Location - Off
    Tap to Send - Off
    Let it complete a few charge cycles.
    08-29-2013 11:51 AM
  3. Neeraj Parihar's Avatar
    Bro everything s turned off bt,nfc,location high sensitive still it drains more over recharge time s so longg
    08-29-2013 12:10 PM
  4. montsa007's Avatar
    Let the phone complete 4 full charge cycles.
    08-29-2013 12:15 PM
  5. Neeraj Parihar's Avatar
    Almost 8-9 cycles hv been completed until now
    08-29-2013 12:22 PM
  6. montsa007's Avatar
    Are you using the official charger?
    And do you let it charge completely instead of charging in installments?
    Try a soft reset - Vol Down + Power button, phone will switch off, release the buttons and it'll reboot, you won't lose any data.
    08-29-2013 12:24 PM
  7. Neeraj Parihar's Avatar
    Yea m using official charger...i did full 100% recharge today that too twice..even did soft rest still same
    08-29-2013 12:31 PM
  8. montsa007's Avatar
    Nokia Care Centre - Replacement.
    08-29-2013 12:36 PM
  9. Neeraj Parihar's Avatar
    They ll replace the battery or whole phone.....?
    08-29-2013 01:06 PM
  10. montsa007's Avatar
    Whole thing as this is unibody.
    08-31-2013 04:29 AM
  1. Is there a 'right' microSD card to buy?
    By iknowsingh in forum Samsung ATIV S Neo
    Last Post: 09-17-2013, 02:47 PM
  2. Replies: 18
    Last Post: 09-13-2013, 09:20 AM
  3. Touch Cover Issues (Wearing off/ split at seam etc)
    By xaviertt in forum Microsoft Surface for Windows RT
    Last Post: 09-09-2013, 04:25 PM
  4. comments on store shows my name as 'user' and not the account name.
    By Dheeraj Sukumaran in forum Windows Phone 8
    Last Post: 09-06-2013, 10:37 AM
  5. Post your "wow, this camera rocks" moment or pics.
    By redeyss in forum Nokia Lumia 1020
    Last Post: 08-29-2013, 09:50 AM
