Today I charged my phone from 10% to 100% for 2hours and 15mins but estimated time shows 16 hours of battery remaining, normally it shows 1day and 1hour or 1day and 4hours ,
Is this normal..?
Is this normal..?
absolutely normal. are you on wifi ?
That's normal. The estimated time isn't always accurate that's why it says 'estimated'. My 720 says the estimated time remaining is 16 hours, sometimes 18 hours but it usually reaches up to 2 days and 4 hours of use.
How you got more than 2days of battery backup...??
I regularly get two days between recharges. It really does completely depend on how you use your phone, what background tasks you have enabled and what apps you use. Try reading one of the many, many threads about maximising battery time on this forum or in the wider internet world.
I don't use 2G or 3G net. Location and nfc are off. Glance and flip to silent are also off.Wifi on when needed. Whats wrong os my battery faulty??I usually turn off some of the background tasks of apps which I rarely use. I also turn off the location setting, and cellular data when not in use. It all depends on how you use your phone and how you tweak the settings according to your preferences. I get two days of battery life even if I listen to my music and radio for several hours, play games, post status updates to Facebook every now and then, upload photos to 6tag, and even watch videos on myTube for hours.
i found out that data connection (always on) is the main culprit for the massive battery drain. u might want to turn it off if you're not using the phone (eg; sleeping)..
Are you using wired or wireless charging ???
