1. DevSolanki720's Avatar
    I reset my Lumia 720 and it took entirely a day and trurned off itself.when connected it to charger it started reseting again showing two gears rotating on the screen and nothing else happens.I kept it that way for almost 15 hours.Worst thing is that I can't soft reset or hard reset my phone as my volume down key is not working.
    anybody here can help me ???
    Thanks & Regards,
    Dev Solanki
    11-11-2013 04:57 AM
  2. mtiede's Avatar
    Seems like when I updated my phone I had to just turn it off because the gears kept turning. I was worried that it would brick the phone, but it just booted normally.
    11-11-2013 05:27 AM
  3. DevSolanki720's Avatar
    Damn this
    again stuck on two spinning gears,anybody plz help my phone is stuck on spinning gears and can't do any type of reset as volume down key not working
    11-11-2013 08:09 AM
  4. farhanmariz's Avatar
    You can use this method to recover it. Worked for me last night. :)
    Tutorial: How to fix the endless spinning gears/cogs bug (for Nokia Lumia users only)
    11-12-2013 02:41 AM
  5. Sneha Bhattacharya's Avatar
    how long did it take to boot automatically after the spinning gears?
    02-28-2014 07:58 AM
  6. shmsnh's Avatar
    If you're stuck at the spinning gears after a hard reset, do a soft reset by pressing the power and volume down keys together for fifteen seconds. If that doesn't work, you might have to use Nokia's Software Recovery Tool.
    03-01-2014 10:05 AM
  7. Cesar Gomez Hernandez's Avatar
    a little trick:
    When you want to restart the phone, just detach battery and put again QUICKLY.
    03-01-2014 10:21 AM
  8. shmsnh's Avatar
    a little trick:
    Yeah, but the last time I checked, Lumia 720 had a non-removable battery.
    Colleta Wambua likes this.
    03-01-2014 11:39 AM
  9. Punit Ahlawat's Avatar
    05-25-2014 05:28 AM
  10. Punit Ahlawat's Avatar
    hey please give me a suggestion on how i get my phone back to normal
    05-25-2014 05:31 AM
  11. Mohammed Ashar's Avatar
    Download Nokia Software recovery Tool in your PC. Your bricked phone will be able to work after the OS has been reinstalled.
    05-31-2014 10:34 AM
  1. Replies: 6
    Last Post: 01-18-2014, 03:09 PM
  2. Replies: 2
    Last Post: 11-28-2013, 10:57 AM
  3. Help required please - Unlocking AT&T locked Lumia 1020
    By Dimi7287 in forum Nokia Lumia 1020
    Last Post: 11-22-2013, 10:40 AM
  4. Lumia 800 parts
    By TheLiege in forum Nokia Lumia 800
    Last Post: 11-17-2013, 02:34 PM
