1. bhavya26's Avatar
    I just got to know that my nokia lumia 720 camera was inferior to the one my friends had.guys can someone help out how can it have such a huge difference.
    each and every settings of my phone and my friends phone were the same.just check out the images.
    As you'll can see theres a huge difference in the image quality
    guys plz help
    03-29-2014 12:57 PM
  2. bhavya26's Avatar
    the first one is mu nokia lumia 720
    while the second one is my friends nokia lumia 720
    03-29-2014 01:20 PM
  3. bhavya26's Avatar
    my*
    03-29-2014 01:22 PM
  4. Pratham Sarwate's Avatar
    did you use the in-built camera app or nokia camera?
    also (if you used the in-built app) did you use the dedicated camera hardware key or tap on the screen to shoot?
    03-29-2014 01:28 PM
  5. bhavya26's Avatar
    i used inbuilt camera in both the phones with camera hardware key
    03-29-2014 01:34 PM
  6. siddharth1102's Avatar
    Try cleaning camera lens.
    03-29-2014 10:38 PM
  7. bhavya26's Avatar
    tried so nothing happened
    03-30-2014 12:15 AM
  8. bhavya26's Avatar
    my phone pics bad even to nokia lumia 625
    nokia lumia 720 nokia lumia 625
    03-30-2014 12:29 AM
  9. anon5997296's Avatar
    Go to Nokia care and show them
    03-30-2014 12:53 AM
  10. bhavya26's Avatar
    have contacted nokia care online waiting for their call because i am fed up with these ppl because just 10 days back i had visisted them 4 times in a week with loads of problems
    03-30-2014 01:14 AM
  11. JuxJake18's Avatar
    Click image for larger version.
ID:	60866 Click image for larger version.
    it's the imaging process thats gone wrong with the lumia 720. Nokia has not solved this issue, and i think it will never try to solve this issue. May I ask if your phone is updated to Black or Amber?
    if so, we've experienced the same issue, there is one solution though: Downgrade back to GDR1. If you don't want to downgrade you should wait for the 8.1 update, if that will solve the issue :)
    03-30-2014 09:46 AM
  12. bhavya26's Avatar
    but even when compared with other lumia 720s the image quality is bad
    03-30-2014 01:03 PM
  13. JuxJake18's Avatar
    http://forums.windowscentral.com/nok...wngrading.html
    you should check this thread :)
    the black/amber update are the ones that messed up the 720. In your first picture comparison, did you and your friend have the same Lumia Black update?
    03-30-2014 09:00 PM
  14. bhavya26's Avatar
    yes both were lumia black updated lumia 720s
    03-30-2014 11:36 PM
  15. Darko Radovanovic's Avatar
    I think this is a hadware issue, the lens on 720 is made of 5 elements, if phone is droped or similar and one of those elements move it will give results like these. I droped my canon camera 50mm lense and got same blurry picture as this one. I have black update on my 720 and still my pics are better then iphone 4s and galaxy s2... So I doubt that software is problem...
    Sent from my RM-885_eu_hungary_334 using Tapatalk
    03-31-2014 07:16 AM
  16. JuxJake18's Avatar
    Since I've downgraded my Lumia, I haven't had any issues related to that kind of blurriness in my phone anymore. I also have not dropped my phone since it was in GDR1 up to GDR3, when I've upgraded my phone to Amber, these blurriness issue started to come out, and after I've updated it to Lumia Black, the photo algorithm stayed the same as it was in the Amber update, which where of the same quality in these photos. So for me, it's the software that has the issue, specifically the "Imaging Post-processing / Photo Algorithm" (I don't know what's the correct term) .
    03-31-2014 09:05 AM
  17. JuxJake18's Avatar
    that's good to hear that you don't have any issues after updating your lumia to black, I really don't know why other 720's, including mine, have these kinds of camera issues. I've tried other Black ROMS, Hard reset the phone, restored default settings in the camera, but nothing worked, and my last option was to downgrade back to GDR1, which solved the issue.
    03-31-2014 09:07 AM
  18. Darko Radovanovic's Avatar
    Maybe I can somehow printscreen and show you info so you can see what black rom it is, maybe it has something to do with countries... I seen that phone is manufactured in Hungary, I am in Serbia so most Nokias we got here are Hungary manufactured....
    Sent from my Lumia 720 using Tapatalk
    03-31-2014 03:46 PM
  19. JuxJake18's Avatar
    that would be great I've tried the France rom and the camera was still the same, and also the Philippines rom and the camera was worse than before.
    03-31-2014 07:47 PM
  20. Darko Radovanovic's Avatar
    Here it is guy's hope it will help somehow...
    JuxJake18 likes this.
    04-02-2014 02:55 AM
  1. Nokia Lumia 1320 User Reviews
    By hopmedic in forum Nokia Lumia 1320
    Last Post: 04-30-2016, 08:08 AM
  2. Lumia 1020 screen blurry while scrolling
    By Lawrence Crecy in forum Nokia Lumia 1020
    Last Post: 08-12-2014, 07:36 PM
  3. Replies: 5
    Last Post: 04-07-2014, 10:50 AM
  4. WTS: Lumia 1520 with extras and excellent condition
    By feedmylittletroll in forum Marketplace Archive
    Last Post: 03-31-2014, 11:04 PM
  5. Camera flash not working
    By chefster74 in forum Nokia Lumia 928
    Last Post: 03-29-2014, 03:23 PM
