1. pandiarajan k's Avatar
    i m using lumia 730 4 last 15 days it gets plastic molten smell inside the shell sometimes heated both sides of the cell..... the mobile does not charged full and it shows 100% hen it drains quickly..... then sometimes while i m using mytalking tom & uc browser it closes automatically then i tried to open it again it closes he app.....pls help me
    12-08-2014 02:03 PM
  2. onysi's Avatar
    Its a common issue for phones, id usually just return it and g3et another one. My Lumia 635 had that issue. Traded it in and no problem since.
    12-08-2014 02:23 PM
  3. RCOPEH's Avatar
    Man, gutting. That sounds like a real fault and will need to be returned. I've had numerous phones that do this and it winds me up no end.
    12-09-2014 05:18 AM
  4. emperor_skull's Avatar
    Check your network speed and settings, and check how good your network is around your area, if is not that good switch to 2g, try opening third party apps, all of them, open and wait for them to load then close them, you can also do the same to system apps, uninstall apps you rarely use, go to your email settings and switch the sync status to manually, then clear temp files in the storage sense, when the battery is fully charged, turn it off with the charge still plugged in and allow it charge again, hope this helps
    12-09-2014 05:50 AM
  1. Dead Nokia Lumia 1520 - Glass/LCD intact
    By Talderon in forum Marketplace Archive
    Last Post: 01-08-2015, 07:51 PM
  2. Simple "Modern App" Games (i5 and i7)
    By bschiav in forum Microsoft Surface Pro 3
    Last Post: 12-29-2014, 01:51 PM
  3. Why won't my Nokia Lumia 520 (windows Phone 8.0) read my sim card?
    Last Post: 12-08-2014, 05:57 PM
  4. Out This Week on Xbox One: Lara Croft and the Temple of Osiris and Giana Sister: Twisted Dreams
    Last Post: 12-08-2014, 01:00 PM
  5. My lumia 625 says that its running lumia denim. Is that normal?
    By Alexander Hunt in forum Windows Phone 8.1
    Last Post: 12-08-2014, 11:57 AM
