1. v535's Avatar
    Hey everyone, after a hard reset I tried some games and apps and decided to uninstall some apps. After uninstalling some apps, I must regain some space but some data is leftover thereby resulting in partial uninstallation of apps. Currently only 1GB is free, mind you I did a hard reset just couple of months back. What should I do, will w10m solve these issues? Will moving the apps to sd card result in battery drain?
    AFAIK, frequent hard resets will eventually increase wear/tear on eMMC, now what should i do?
    02-23-2016 09:24 AM
  2. pankaj981's Avatar
    Have you tried clearing temporary files or browser history? Even apps like WC end up taking cache memory.
    libra89 likes this.
    02-23-2016 09:50 AM
  3. Arunabha Goswami's Avatar
    There's an app called Storage Cleaner. Give it a try.
    02-23-2016 10:05 AM
  4. v535's Avatar
    Tried everything in Wp8.1 playbook. Even I filled up the entire disk using storage cleaner app and instead of freeing up the space it increased by several 100 megs. The problem is, i play a game until completion and then I uninstall it. In wp8.1 I must keep the unused apps on phone memory to prevent ever increasing other storage. Looks like, a reset can fix it, will try once stable w10m is rolled out.
    02-23-2016 11:07 AM
  1. New user - app recommendations needed & help!
    By mmarksx19 in forum Microsoft Lumia 950 XL
    Last Post: 02-26-2016, 10:35 AM
  2. Loved my 950XL before, but now love it even more :)
    By Asfalloth in forum Microsoft Lumia 950 XL
    Last Post: 02-25-2016, 01:38 PM
  3. Can I get some help updating my phone?
    By devinda in forum Windows 10 Mobile
    Last Post: 02-23-2016, 01:07 PM
  4. See if your PC is ready for virtual reality with the SteamVR Performance Test
    Last Post: 02-23-2016, 08:20 AM
  5. My download is stuck with starting to download why??
    Last Post: 02-23-2016, 08:16 AM
