1. webnoi's Avatar
    Hi all,
    I just got a new Lumia 800 in replacement to my old Samsung Focus.
    Everything seems to be OK with the phone after I installed the 12070 (fixed a lot of sound bugs).
    When I installed the Fastball 2 game (I love it) i got disapointed. The background music is lound and the sound efects volume is too low (majority of the sounds is inaudible). If I play the game using the headphones the game get way better and I can hear almost all the sounds.
    This problem doesn't occour on my old Samsung Focus or with the HTC Titan of a friend. Someone can test if this problem occour only with my device or all Lumia 800?
    Thanks in advance.
    05-14-2012 02:03 PM
  2. Mio_Ray's Avatar
    It's the 12070 Volume bug. It is fixed on 12072 which is currently rolling out. Impatient ? Do it via Cab Sender, just search 12072 for instructions :)
    Sent from my Lumia 800 using Board Express
    05-15-2012 09:33 AM
  3. webnoi's Avatar
    No... The update 12072 don't fix it.
    I already have it installed...
    05-15-2012 10:55 AM
Tags for this Thread
