I've had my Lumia 810 for a while and I'm noticing the battery is draining out unusually fast. When I'm not using it, even overnight, I notice it's just eating my battery like power is going out of style. I've looked around for tips to save on battery life and I've done the usual but it doesn't seem to be of much help. I just reset my phone to clear any lingering nonsense that might have been running. Anyhow, I disable the usual things like NFC, Bluetooth, connecting with Xbox Live for games and music, my lock out time is one minute, I've changed my screen brightness to low, etc etc. Battery saver is running for when the charge is low. Is there anything else I should be doing or changing?
Additionally... are there any free battery monitoring apps that are robust enough to tell me exactly what drains my battery life? If there aren't freebies, are there any apps at all that can do that?
