1. mjaiteh's Avatar
    I just ordered a Lumia 810 with a charging shell, but I am in need of a case!
    Does anyone know any cases that fit over the charging shell? Also any screen protector recommendations?
    This is the only option I know of so far:
    08-17-2013 01:53 PM
  2. Moises Corilloclla's Avatar
    Where did you get it? Just curious...
    08-17-2013 03:07 PM
  3. mjaiteh's Avatar
    Ebay...
    08-17-2013 04:44 PM
  4. xtsubarublazin's Avatar
    I followed another thread on this forum that discusses modifying the original case with the wireless charging equipment, and therefore opening the opportunity up to have any case on the market. I purchased some nice colored cases from eBay and they work great over the original shell, which now wirelessly charges on my device.
    sabrekane likes this.
    08-18-2013 11:57 AM
  5. mjaiteh's Avatar
    Could you give me the link?
    08-18-2013 01:44 PM
  6. JM_T's Avatar
    I have the tech21 d30 case fitting really tight over my charging shell. I saw some on ebay going for ~$9 each. On the other hand, you have a Cyan cover... Maybe look for one of those clear jelly rubber cases out there so you could at least rock that color
    08-18-2013 02:04 PM
  7. xtsubarublazin's Avatar
    Link to post about wireless charging mod: http://forums.windowscentral.com/nok...mia-810-a.html
    Worked perfectly for me.
    08-18-2013 03:35 PM
  1. Does WP8 enable you to work on the go?
    By TechFreak1 in forum Windows Phone 8
    Last Post: 11-11-2015, 10:19 PM
  2. Take loads of photos at once???
    By SoullessOnyx in forum Applications
    Last Post: 08-19-2013, 04:45 PM
  3. Im kind of stock in 2009
    By iamwindows in forum Nokia Lumia 920
    Last Post: 08-17-2013, 03:54 PM
  4. Show time on internet explorer
    By Darren Walsh in forum Windows Phone 8
    Last Post: 08-17-2013, 01:47 PM
  5. Replies: 1
    Last Post: 08-17-2013, 12:41 PM
