1. worldspy99's Avatar
    Anyone else notice a severe battery drain whilst the phone is in airplane mode? Mine goes from full to 20% in a few hours, whereas it loses maybe about 5% in standby mode with Wi-Fi and cellular data on. Just wanted to find out if anyone else has noticed the same problem or not?
    06-14-2014 11:28 PM
  2. Laura Knotek's Avatar
    What OS version are you running on your 810?
    06-15-2014 12:13 AM
  3. AmGaD-SaLaH's Avatar
    Same thing on my l1320
    But it's drop from 97% to 80% in hour
    06-15-2014 12:27 AM
  4. metalchick719's Avatar
    That's crazy! I can't recall if I ever used my 810 in Airplane mode, even when my boyfriend and I flew to Florida early last year. It really shouldn't drain the battery at all, though.
    06-16-2014 09:38 AM
  5. worldspy99's Avatar
    Only in Airplane mode. I am running 8.10.12393.890.
    Without airplane mode it lasts over 24 hours:-)
    06-16-2014 10:58 AM
  6. Guzzler3's Avatar
    That's really weird. A couple weeks ago I went for long motorcycle ride into areas where I knew I wasn't going to have cell service so I turned on Airplane mode (to avoid having the phone search for any cell or Wi-Fi) and only used the phone to play music. After 6 hours I went from 100% to 82% battery capacity.
    I only turned off Airplane mode when I was taking rest breaks, and I knew I was in areas, towns that had cell service and needed to look things up (restaurants, gas, check messages, etc.). A couple of times I kind of got lost and had to use Here Drive+ and the downloaded maps, with Airplane mode turned ON, to find my way and to have audible speed warnings.
    After 24 hours of doing this, I ended up with the battery at around 67%. Pretty good in my opinion. I did something similar when I first got my 810, but never turned on Airplane mode (I just forgot about that setting) and the phone died after 7 hours of use because it was always trying to find some sort of network.
    Granted, I did do a factory reset the day before (trying to clear up some XBM issues so I would try to have a decent music experience).
    worldspy99 likes this.
    06-17-2014 09:47 AM
  7. worldspy99's Avatar
    I updated the phone to the latest WP 8.1 OS version last night and am flying to Minnesota tomorrow, I will post a further update and let everyone know how things are going. Thanks for sharing your experience Guz.
    06-17-2014 10:28 AM
  8. Muhammad Fayed's Avatar
    I had it yesterday ..
    I turned it on at 6:00PM and it went from ~75% to ~20% in just ~5 hours without using the phone for anything else. I just wanted it silent and enjoy a day off.
    after reaching 20% I think the system is trying to extend the battery life .. so it kept going for a while until I found my phone off today.
    I have Lumia 1520 but It's same problem all over.
    06-20-2014 04:02 AM
  9. worldspy99's Avatar
    I decided to just power down the phone while in flight and use my tablet instead on the plane. I needed to conserve battery for using HERE Maps once I reached Minneapolis. I think MSFT needs to know about this bug.
    06-20-2014 09:57 AM
  10. Mr Lebowski's Avatar
    If it doesn't happens on current model Windows phones ... MS won't do a thing.
    06-20-2014 02:09 PM
  11. worldspy99's Avatar
    This is why I'm moving to a Lumia 925 from my trusty 810.
    06-20-2014 10:45 PM
  12. Mr Lebowski's Avatar
    Set to Airplane mode @ 88% 3 hrs later 0.9% drain per hr. - to 87% I didn't update to 8.1.
    06-25-2014 07:09 PM
  13. pankaj981's Avatar
    That's 0.3% per hour :)
    JM_T likes this.
    06-25-2014 07:12 PM
  14. Mr Lebowski's Avatar
    ^ +1 You're right but I was referring to the the graph (which I failed to mention) from the Battery Sense App which I reset before Airplane mode -that's what it read & I didn't bother to calculate it !
    06-27-2014 02:03 PM
  1. Surface Pro 3 In Stock and shipping from TigerDirect.com
    By Isror in forum Microsoft Surface Pro 3
    Last Post: 06-17-2014, 05:50 PM
  2. 12397 has broken Twitter integration in People Hub
    By Lethbridge in forum Windows Phone 8.1 Preview for Developers
    Last Post: 06-16-2014, 02:03 PM
  3. Replies: 2
    Last Post: 06-16-2014, 09:51 AM
  4. Replies: 21
    Last Post: 06-14-2014, 10:42 PM
  5. Guess That, three trivia games in one for your Windows Phone
    Last Post: 06-14-2014, 02:42 PM
